Activity Forums Adobe After Effects Foamy Bubbles question
  • Foamy Bubbles question
    Posted by Moog Gravett on January 24, 2013 at 5:02 pm
    Hi folks,
    I’m trying to create some cartoonish, foamy bubbles but have encountered a problem that I hope you can find a solution for.
    Currently, I’m using the built in foam, as it’s actually pretty good for what I’m after with one exception. The bubbles keep popping in a whole wave and starting all over again, so they only ever build up to a certain point. I want them to keep building and building so they take over the scene.
    I’ve experimented with the lifespan right up to the max, but it keeps on just the same. I can’t find anything else that appears to alter this effect.
    I’ve got a ref vid of the current situation here…
    https://reels.creativecow.net/film/18928
    any ideas?
    Perhaps there’s a better way using particular, but I’ve never tried sticking particles together in there.
    Cheers
    Moog
    Freelance | Video Editor | After Effects | Camerawork
    http://www.Peculiana.com
    Moog Gravett replied 13 years, 8 months ago 2 Members · 3 Replies
  • Moog Gravett
    January 24, 2013 at 5:46 pm
    Hi Dave,
    appreciate the reply,
    Sorry, I might not have made it too clear, but this is the effects I’m using.
    Cheers
    Moog
  • Ridley Walker
    January 24, 2013 at 7:54 pm
    The lifespan is is calculated in frames, there is a ‘feature” that is confusing: the bubble size will affect how far the bubble travels over its life.
    Smaller bubbles travel further. Try adjusting the production rate and the bubble size.
    I’m assuming you’re *not* using a Flow Map to restrict where the bubbles travel.
  • Moog Gravett
    January 25, 2013 at 8:15 am
    Thanks for the tips,
    I’m coming to the conclusion that this Foam effect is too unwieldy for what I need. It’s a shame, because the physics of it are quite nice.
    I think I’ll render out a small section of bubbles and just duplicate that all over the place 😉
    cheers anyway
    moog
