Activity Forums Adobe After Effects foam pre comp stutter
  • foam pre comp stutter
    Posted by Roger Burton on March 30, 2006 at 9:53 am
    Hi all …wierd this one … I have foam generating some particles and I want them to cast a shadow so I precomped … the precomp plays smooth but the comp (in which the precomp is … whatever it’s called … comp I guess) has developed a stutter/jitter as if every few frames or so frames are dropped and the generating foam jumps … I’ve looked at everything … turned off the effect … to no avail. When I render out the movie and bring it into the comp it’s fine … guess it’ll be one of those things I’ll never get to the bottom of unless anyone has come across the problem before ?
    Thanks for your time Roger
    Roger Burton replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
