Activity Forums Adobe After Effects Flying Lights
  • Flying Lights
    Posted by Tim Robinson on April 21, 2008 at 4:38 pm
    I was wondering if their an easier way of creating “flying lights”… small bright dots that make streaks (if you still don’t know, see the Ipod nano how-to, that’s sort of the same thing, but with constant streaks). I’ve tried particle illusion, but the rendering seems all to slow to make continuous streaks and to make them fly in a correct 3d space…. whey I try to make them spin, turn, etc on screen, they never seem to go in the right direction. Doing 1 is hard enough, doing more than 1 at a time is way to time consuming and often fruitless.
    Please help!
    Tim Robinson
    tim@erobinsons.com
    Pride-Mobility-Products
    Corporate Video Editor
    Ian Corey replied 18 years, 4 months ago 3 Members · 3 Replies
  • Tim Robinson
    April 21, 2008 at 4:53 pm
    Not sure if I made myself clear, but that was the how-to I was refering too. I was looking for some tips/advice on how to do it more effecticly with better control of the lights in 3d space. Particular is hard to control to keep a steady/solid streak going as well. Sorta like WSVN’s light style.
    Tim Robinson
    tim@erobinsons.com
  • Brian Berneker
    April 21, 2008 at 4:58 pm
    Basically you create a null or other 3D object and parent your particle position to it.
    Maltaannon’s tutorial on growing vines in AE uses such a technique to keyframe the movement of a light to control the position of particles in Particular. You might want to check that out…
    Brian
  • Ian Corey
    April 21, 2008 at 5:56 pm
    That’s 3D Stroke with Glow applied.
    Man, that news station is trying WAY too hard to be hip.
