Activity Forums Adobe After Effects Fly in and rotating a lot of layers
  • Fly in and rotating a lot of layers
    Posted by Brent Van den abbeele on November 10, 2011 at 12:36 pm
    I worked most of the time with Motion but for this project I’m using AE. I know the basics, but like I said I’m used to the Motion workflow.
    I want to animate a lot of objects (square’s around a text), they have to fly in and afterwards they have to keep on moving slowly.
    Then the text pops in.
    I’ve got every square and the text in different layers, pre-comps… So normally I can do anything I want with it…
    It’s for this festival, look at the logo on the top left corner of the site: https://www.tfestival.be/
    Brent Van den abbeele replied 14 years, 10 months ago 3 Members · 6 Replies
  • Michael Szalapski
    November 10, 2011 at 3:37 pm
    If I follow what you’re saying, you could parent all of your squares to a null object that’s slowly moving, then animate them to fly in when needed. That would be the easiest way to get them to fly in, move slowly, then fly out.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Walter Soyka
    November 10, 2011 at 3:42 pm
    Or make them all 3D layers, distribute them in Z-space, and add a simple floating animation to the camera.
    Walter Soyka
  • Michael Szalapski
    November 10, 2011 at 3:44 pm
    Or use Sure Target from VCP!
    – The Great Szalam
  • Brent Van den abbeele
    November 10, 2011 at 4:03 pm
    The sure target isn’t really what I need. I got the circle to move slowly with a camera movement. Now all I need is the fly in? I don’t seem to get it working…
  • Walter Soyka
    November 10, 2011 at 4:09 pm
    [Brent Van den Abbeele] “I got the circle to move slowly with a camera movement. Now all I need is the fly in? I don’t seem to get it working…”
    What have you tried? I know you have a Motion background, so you may be inclined to use behaviors, but most animation in AE is done with keyframes.
    I’d keyframe the position of each layer, starting it off-screen and flying it on-screen.
    If you’re new to After Effects, I’d recommend the following link, in which Adobe’s Todd Kopriva pulls together some important introductory materials:
    https://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.html
    I especially recommend the Video Copilot “Basic Training” series that Todd links to.
    Walter Soyka
    November 10, 2011 at 4:14 pm
    Hi, I got it to work. I have to admit, little bit embarrassed, I tried to apply a text preset on an object. So now I’ve used the Fly to Insent preset and that seems to work. Not how I had in mind, but it works…
    So thanks.
