FLV with Alpha Output options & Project Settings
Hi there,
We are creating .flv videos for the web with transparent backgrounds, hence FLV with Alpha. We wish to produce the best possible quality with the smallest file size. Our greenscreen footage is shot with a Sony XDCAM HD422 PMW-100 using a UDF HD Mode of HD422 50/1080/25P.
Here our Project Settings
– Are we using the correct Working Space?
– Should we be secting any other options (i.e. Linearize Working Space)?Here our Output Module Settings – Main options
– Color as “Premultiplied” or “Straight”?Here our FLV Options
– VBR or CBR as Bitrate Encoding?
– Bitrate kbps… the higher the value the better the quality but the bigger the file size – right?Here our Output Module Settings – Color Management
– Settings OK?Thanks for any further tips.
