Activity › Forums › Adobe After Effects › FLV from Render Queue
  • Steve Roberts
    November 6, 2007 at 10:10 pm
    Certain non-Quicktime formats can only be accessed from the Export menu. That can include SWF, FLV, WMV, WAV, clip notes and others.
  • Michael Tesh
    November 7, 2007 at 1:18 pm
    So there is no way to batch render these then?
    Thanks for the info.
  • Todd Kopriva
    November 7, 2007 at 3:29 pm
    Which version of After Effects are you using? In After Effects CS3, Adobe Flash Video is the second entry in the Format menu in the Output Module Settings dialog box.
    Todd Kopriva, technical editor, Adobe Systems Incorporated
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    How about taking a survey about After Effects documentation? Please?
  • Luciano.higuchi
    November 7, 2007 at 3:51 pm
    I have the same problem. The version I’m using is CS3.
    There is no adobe flash video in a list of available formats in output module in render queue. according to many different documents this feature is a part of new cs3. but it’s not there.
    Why?
  • Luciano.higuchi
    November 7, 2007 at 3:56 pm
    Why?
