Activity Forums Media 100 FLV files into m100?
  • FLV files into m100?
    Posted by Greg Ball on May 3, 2005 at 11:52 pm
    Is it possible to take a clients flash video clips and import them into m100i 8.2.1 so I can use the clips in a program? How would do that? Thanks
    Steve Kownacki replied 21 years, 3 months ago 2 Members · 1 Reply
  • Steve Kownacki
    May 5, 2005 at 11:31 am
    2 options:
    it’s been a while, but I think I had my flash guy export sequential stills in the correct aspect and video frame rate and with enough safe area. I think flash by default is 12 fps which will make your video really fast. That was about 2 years ago, the new version of flash probably has setting already.
    one thing i did the other day was to use Snapz ($60US) screen capture software. screen res set for 1280×854; captured a streaming video file with a bounding box at the default of the movie 320×240; capture rate of 30fps; internal sound. brought the file to m100 keeping the aspect; the file was a bit larger than 1/2 screen and (for streaming video) looked amazing! Partly i’m sure because of fewer colors of NTSC.
    steve
