Activity Forums Adobe After Effects flv export from AE is broken
  • flv export from AE is broken
    Posted by Mitch Rosefelt on December 5, 2006 at 3:20 pm
    Hey all:
    For some reason, whenever I try to export an flv from After Effects 7, it just hangs.
    My typical procedure is to choose “custom” in the export window, then choose On2 and choose the various settings. This has been working fine all year, but now when I press the “ok” button, AE just hangs and I have to force a crash.
    I am suspicious of QT 7, which I installed recently. I noticed that the Flash export in QT has a few more tabs than AE, so I’m wondering if it changed something on the system level that is causing AE to choke.
    My efforts to repair the problem includ:
    Uninstall/Reinstall AE 7
    Restore system (WinXP Pro) to previous date
    Uninstall Quicktime (this removes all the the .flv export options in AE)
    Reinstall Quicktime 6 (this restores one of the .flv export options)
    Uninstall QT 6 and Install QT 7 (this restores both .flv export options
    I also attempted to reinstall the Flash Video Encoder, hoping that it would replace the Flash video codec which was installed by Quicktime. When I attempt to “repair” my Flash Video Encoder using the Studio 8 CD, the installer asks for “Disc 1”, which is the disc that it is being installed from. This is getting pretty ridiculous – as a major player in desktop video production, AE should have its own native flv exporter that won’t be modified by the installation of other software.
    Any advice would be greatly appreciated.
    M
    Drtroy replied 19 years, 7 months ago 3 Members · 2 Replies
  • Nicholas Toth
    December 5, 2006 at 3:24 pm
    How long do you let it hang for?
    Sometimes when we output here our windows machines will hang for a good 5-10 minutes depending on where the project and media are located.
  • Drtroy
    December 26, 2006 at 2:51 am
    I’m actually having the same problem and I can’t find a solution.
    Have you solved it ? and if yes can you tell me what you’ve done ?
    That would be really helpful!
