Activity › Forums › Adobe After Effects › Fluids in ProAnimator
  • Fluids in ProAnimator
    Posted by René Martin on January 28, 2010 at 5:25 pm
    Hello,
    At the moment I have to make a medical short film. Therefor I’m using 3D objects imported into ProAnimator in combination with After Effects.
    My problem:
    I have the Model of an injection and now I need to add a Fluid like Blood in the injunction. Is there any way to do this?
    P.S.: Sorry for my bad style. I’m just an english learning pupil.
    René Martin replied 16 years, 8 months ago 2 Members · 2 Replies
  • Erik Waluska
    January 30, 2010 at 12:08 am
    There is no fluid effect in Proanimator but you may be able to fake the effect by texturing the syringe with an animated layer map that you could create in after effects. You could also create a primitive cylinder to represent the fluid inside of the syringe and position it in the syringe and group the objects (parent the cylinder to the syringe).
    If you need to have the fluid coming out of the needle as well then I would use a particle effect in After Effects to do that.
    If I’ve misunderstood what you are trying to do then please provide some more details.
    -E
  • René Martin
    January 30, 2010 at 7:27 am
    no you didn’t misunderstood me, thanks for reply
    I think I’m gonna try the solution with the cylinder inside of the syringe…
