Activity › Forums › Apple Final Cut Pro › Flow Transition
  • Flow Transition
    Posted by Winston A. cely on October 11, 2019 at 12:19 pm
    Hey folks, I have an interview where I used a Flow transition to cover a small jump cut. It worked perfectly! That is, it worked perfectly until I put a blank adjustment layer over the transition. I wait until I’ve completed all my mixing, color correction, etc before I put a blank adjustment layer over the whole project in order to use the Letterbox filter and crop my image to 2.35:1. In this project, as soon as I do that, the Flow transition simply turns into a dissolve. I turned off the adjustment layer, and it works, turn it back on and it stops working. I deleted all my render files and tried again, but no luck. Anyone else ever had this problem?
    Winston A. Cely
    ACTC Media Broadcasting Video Instructor
    Apple Certified Editor FCPX 3
    \”If you can talk brilliantly enough about a subject, you can create the consoling illusion it has been mastered.\” – Stanley Kubrick
    Rikki Blow replied 6 years, 9 months ago 3 Members · 5 Replies
  • Winston A. cely
    October 11, 2019 at 5:10 pm
    FYI, the workaround for this is to export out a master file of the clips (any text objects above the transition turned off) with the working Flow transition, then re-import those clips.
    “Why not simply make a new compound clip,” you ask? I tried that, and it gave me the same problem.
    Bit of a hassle to have to export out and reimport.
    Winston A. Cely
  • Craig Seeman
    October 12, 2019 at 12:23 pm
    I’ve also found the Flow transition sometimes is or just becomes a dissolve.
    I use MotionVFX MorphCut instead which works as expected. Annoying that I have to depend on a similar third party effect but Apple’s Flow been inconsistent for me since its release.
  • Winston A. cely
    October 15, 2019 at 7:37 pm
    Thanks for the plugin tip Craig!
    Winston A. Cely
  • Craig Seeman
    October 15, 2019 at 8:39 pm
    You’re welcome of course.
    I find Apple’s Flow to “break” often, becoming just a dissolve.
    MotionVFX MorphCut plugin works consistently.
  • Rikki Blow
    December 8, 2019 at 3:52 pm
    Yes, I’ve had ‘Flow’ fail me on certain projects without any adjustment layer.
    Can’t work out what factor breaks it, but will look at that MorphCut as a backup so thanks for the pointer.
