Activity › Forums › Maxon Cinema 4D › Floating Dust/Snow Particles–Thinking Particles v Mograph
  • Floating Dust/Snow Particles–Thinking Particles v Mograph
    Posted by Jake Nelson-dooley on May 21, 2010 at 5:06 pm
    I’m trying to achieve some floating particles similar to this:
    https://vimeo.com/5236835
    I especially like how the particles collide with the floor and bounce off (though it seems that it doesn’t happen with every particle).
    I started going down the Thinking Particles road, but that seems a bit complicated. Is Mograph a possibility? So far I haven’t found the right combo of MoGraph gravity, Custom mass, etc to evoke a dust mote. But if I could, I wouldn’t have to mess with all the Xpresso to get the dust to collide with the floor.
    Any thoughts much appreciated.
    Jake
    Joey Camacho replied 15 years, 5 months ago 4 Members · 4 Replies
  • Randy Johnson
    May 22, 2010 at 7:11 am
    its thinking particles.
    Here what the expresso looks like.
    Then all you have to do is adjust the settings in the deflector object. To “Object” type.
    Uploaded with plasq‘s Skitch!
    /Randy
  • Adam Trachtenberg
    May 22, 2010 at 2:58 pm
    Or if you want you can use the standard particle emitter with Mograph. In that case you would set a cloner to object mode and then drag the emitter into the object link box. Give the cloner and the ground plane Mograph rigid body tags and away you go.
  • Joey Camacho
    April 6, 2011 at 6:24 pm
    Hey Randy,
    I’ve got everything set up according to the diagram above, but the particle are still falling through my plane (floor)… any suggestions? Thanks in advance!
    J.
  • Joey Camacho
    April 14, 2011 at 4:03 pm
    Ahhh….don’t forget to make your particle an editable object.
