Activity › Forums › Adobe After Effects Expressions › flipping positive for negative from rotation controller
  • flipping positive for negative from rotation controller
    Posted by Mike Roberts on March 4, 2014 at 2:26 am
    Hey guys,
    I have a null with the y position being affected by the rotation. when you rotate the null into the negative, the y position moves down… very simple:
    value – transform.rotation*5
    what i need is something in there so that when the rotation is positive, the expression changes to:
    value + transform.rotation*5
    To try and explain further – i want the y position to go down the same amount when the angle of the rotation is at +15 or -15, 0 degrees being the highest point.
    Is that doable??
    Mike Roberts replied 12 years, 6 months ago 2 Members · 3 Replies
  • Mike Roberts
    March 4, 2014 at 2:48 am
    I DONE FIGURED IT OUT!
    value + (Math.abs(transform.rotation*5))
    is there a better way??
  • Dan Ebberts
    March 4, 2014 at 3:23 am
    That’s how I’d do it.
    Dan
  • Mike Roberts
    March 4, 2014 at 5:27 pm
    Thanks Dan!
