Flipping Paper in Flash
I have searched HIGH and LOW to find out how on earth they do that paper flipping effect on many of the Template Monster sites for Flash sites. I eventually have been told through the forums that it’s been done through AE.
Now, after much fiddling and playing, I managed to get my first one right but now I am stuck on a my next project with a more specific effects I am trying to get right.
Basically, I need to start with a rectangle shape which has been skewed and then it needs to flip like paper and eventually end up in a normal rectangle shape, but much larger.
Unlike Flash though, I am not using vectors, so I cannot just set the start shape, then a keyframe to the end shape and tell it to tween.
I can put it into a mask, but it seems it cannot animate the mask, it animates the object BEHIND the mask which is not what I want.
Any help would be appreciated.
Here’s an example:
https://www.goforgold.org.za/proof.htmlThe cube’s right side needs to unfold into a big rectangular area which will be used for the sites’ content area.
Many thanks,
SkyThanks,
Sky
