Activity Forums VEGAS Pro Flip video AVI problem
  • Flip video AVI problem
    Posted by Will Ballard on January 24, 2009 at 8:25 pm
    Alright, so whenever I split an AVI file from my Flip video camera it seems to mix frames around. For example; I’ll split a video then somewhere in the video, where I haven’t even touched, has a frame switched with another frame from a couple seconds before. I don’t know if anyone else has had this problem, and I can’t figure out how to fix it! I have the latest build. Can anyone help?
    John Rofrano replied 17 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    January 25, 2009 at 2:51 pm
    Flip uses some non-standard MPEG4 format. It is possible that Vegas is having problems decoding it. You might want to use another program to convert the video to a format that is easier for Vegas to edit and see if that fixes the problem. Any video converter will do but Super(c) seems to be a fairly good one. Vegas likes DV for SD or MPEG-2 or AVCHD for HD but MJPEG, HuffYUV, or Lagarith codecs can also be used with both SD & HD with good results.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
