Activity › Forums › AJA Video Systems › Flip HD
Flip HD
Posted by Matt Kerstein on December 21, 2009 at 10:24 pmAnyone have a good workflow getting flip720P30 .mp4ʻs to playback thru Kona to a monitor after converting to whatever flavor gets best results?
Aloha & Mahalo from Maui
Matt Kerstein replied 16 years, 9 months ago 3 Members · 4 Replies -
Shane Ross
December 22, 2009 at 12:29 amConvert it to PRO RES…via MPEG STREAMCLIP or Compressor… and then choose the Kona ProRes setting for the format you converted to. Works fine.
Shane
Read my blog, Little Frog in High Def -
Matt Kerstein
December 22, 2009 at 2:08 amThanks Shane,
Did Pro Res via compressor but had playback issues till I realized that I needed to convert to 720P 59.94. Flip shoots 30.Aloha & Mahalo from Maui
Gary Adcock
December 23, 2009 at 2:50 pm[Matt Kerstein] “Anyone have a good workflow getting flip720P30 .mp4ʻs to playback thru Kona to a monitor after converting to whatever flavor gets best results? “
I use the HDMI> HDSDI conversion to capture, it offers significantly better signal than a software conversion does.
On set I use the aja HA5 converter ( HDMI- HDSDI) or now a KiPro, works for output from the Canon DSLR’s also.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Matt Kerstein
December 30, 2009 at 7:47 pmThanx for the info gary..BTW great article on Pro Res “a closer Look”
