Activity Forums Apple Final Cut Pro Legacy flip 4 mac HELP
  • flip 4 mac HELP
    Posted by scottwitt Scott witt on September 6, 2007 at 1:41 pm
    Hello all,
    I need to export a sequence that is the standard 32 bit floating point at 48000KHZ, but the clip was captured in 16 bit integer
    47999KHZ.
    When I try to use flip 4 mac to convert to a PC powerpoint it says inconsistent audio sample rate, I have done this in the past without this problem.
    I have tried exporting the audio as .wav and various other things. I can’t get the user to just eliminate my headache and use a MAC, he should be doing the project anyways.
    Anyways, PLEASE throw out ideas. I have a G5 tower with all the updates.
    THANKS!
    Dual gig, 1024 ram all updates
    Bob Auiler replied 19 years ago 4 Members · 3 Replies
  • Mitch Ives
    September 6, 2007 at 2:36 pm
    I believe that is being reported as a problem with QT 7.2. I believe they have a beta and will be releasing a fix soon…
  • Chris Borjis
    September 6, 2007 at 3:08 pm
    You can get the beta now and it does fix it.
  • Bob Auiler
    September 7, 2007 at 1:54 pm
    A workaround for the problem is to change the sequence audio sampling rate to 44 kHz, do an audio render, then it will export fine.
