flickerings / framedrop? on the Intensity Shuttle(fixed)
FIXED !! WORKS PERFECT :D, the mistake i made was that i only instald the driver.
on the same page there are files called DRIVER and FIRMWARE you need to update Both !!
*hi, well i did buy the Intensity Shuttle™, very happy about it because it capturess everyting i tryed so far.
the problem is that het schreen stays flickering like its crazy(like this,not me but i have the same https://www.youtube.com/watch?v=OkSiRXzx3fk)
its not the input (or the output on the TV screen, its on the PC only)
does some one know how to fix that ?
(the sound seems toe go good but the screen just misses frames (that makes that the sound wil end up to be faster then the movie (Bang …. (screen)*explosion*hopefully someone can help me 🙂
ps, tryed so far, HDMI,and the red/wite/yellow plug al the same i fear (used pc, Wii PS3)
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
