Activity Forums Adobe After Effects Flickering text
  • Flickering text
    Posted by Marcosh on January 25, 2007 at 1:44 pm
    Hi there,
    I’ve animated the tracking for my text but when I open it in Final Cut Pro I see it flickering on the vertical lines.
    I checked a lot of the postings related to this topic but apprarently they address only scrolling text. I tried the steps suggested (rendering as fields, adding an adjustment layer with a flick reducing filter, lowering the brightness of my white text) and no luck.
    Would appreciate if anyone had an idea of what else I can do.
    Marcos H.
    AE 7.0 / fcp 5.1.2
    Derrick replied 19 years, 7 months ago 3 Members · 2 Replies
  • Iancorey
    January 25, 2007 at 2:55 pm
    Is it flickering on your computer monitor or your broadcast monitor? Also, make sure it’s at 100% of actual size.
  • Derrick
    January 25, 2007 at 4:09 pm
    What codec did you render out with, I find the same problem if I render out of AE with a DV Codec, try uncompressed.
    – Derrick
