Activity › Forums › Apple Final Cut Pro Legacy › flickering still images
  • flickering still images
    Posted by Yourmemoryisaneditingsuite on August 24, 2005 at 7:21 pm
    Hi, I’ve been having trouble with still images(jpegs) when imported into the timelime…I get a very unstable image, aliased and flickering…At first I thought it was a field problem, but I made sure the image had a lower field dominance like the rest of the sequence, and it didn’t work, then I de-interlaced it and it didn’t work, I used anti-flickering filter and it barely made any difference. There’s got to be a solution. Anyone?
    Leo
  • Bouncing Account needs new email address
    August 24, 2005 at 10:05 pm
    1. How LARGE are your image files?
    2. Where are you viewing them for quality?
  • Olof Ekbergh
    August 25, 2005 at 11:20 am
    Try softening the images. You can do a gaussian blur in photoshop or reduce interlase flicker by softening only in vertical direction.
    Westside A V Studios
  • Yourmemoryisaneditingsuite
    August 25, 2005 at 1:46 pm
    They aren’t large, the largest one is about 100k, but I never blow them bigger than their best resolution permits. I view them on a 20in Sony Trinitron Color Video Monitor with 600 lines of resolution.
    August 25, 2005 at 1:48 pm
    Thanks! I’ll try that.
    August 25, 2005 at 2:41 pm
    [yourmemoryisaneditingsuite] “They aren’t large, the largest one is about 100k, but I never blow them bigger than their best resolution permits.”
    The problem is how large they are in “number of pixels x number of pixels” not the file size.
    A high-resolution computer image will “dance/shimmer/flicker” in a video monitor.
    As was suggested, add the Gaussian Blur filter and adjust it as you view the output on the external video monitor.
