Activity Forums Apple Final Cut Pro Legacy Flickering playback in multiclips
  • Flickering playback in multiclips
    Posted by Stephan Liehr on November 12, 2010 at 1:29 pm
    Both with ProRes422 (SD) and MPEG IMX50 I’m experiencing some kind of flickering playback in multiclip mode after adding a new editing mark in the timeline. Then I have to stop playback and start it again (sometimes more then once) to get a smooth playback again. The flickering seems like jumps to wrong frames around the frames that should be played. Meanwhile audio runs normal. Does anybody have an explanation? I’m using FCP 7.0.3, no software updates seem to be available. Thanks!
    Stephan Liehr replied 15 years, 10 months ago 2 Members · 2 Replies
  • Patrice Freymond
    November 13, 2010 at 11:39 am
    What are your drives? How many streams are you trying to play? What are your RT settings?
    Without more info it is hard to help.
    Patrice Freymond
    Senior editor
    FCP Certified Trainer
    patrice@monteur.tv
  • Stephan Liehr
    November 15, 2010 at 3:13 pm
    Hi Patrice,
    it doesn’t seem to depend on the RT settings, drives or number of streams, as I already edited similar projects on the same machine having no problems. I upgraded FCP a short time ago to 7.0.3 and after this the trouble started.
    Anyways, I’m editing seven streams lying on an internal SATA Raid. The flickering occurs at different RT settings, at both best and dynamic playback, safe and unlimited Realtime (I don’t know the exact english terms as I’m editing with a German surface). I think the flickering looses strength when I turn off the videoscopes-playback.
