Activity › Forums › Apple Final Cut Pro Legacy › Flickering (interlacing?) on video
  • Flickering (interlacing?) on video
    Posted by Kyle Davis on August 25, 2011 at 9:56 pm
    I’m sorry for my utter ignorance, but I’m having an issue where my video is flickering constantly. I guessed it to be an interlacing issue, but added FCP’s de-interlace filter on it, and it didn’t help. Anyone have a guess, or could point me a guide or something?
    Andrew Clancy replied 14 years, 10 months ago 3 Members · 2 Replies
  • Andrew Rendell
    August 26, 2011 at 7:41 pm
    Finding the cause of flickering video can be tricky. It’s not unheard of for interlacing to be involved (making it worse than it would be on a progressive scan), but it’s not usually the cause. More likely are things like filming under fluorescent lights or filming off a computer screen – juggling the shutter speed at the time can usually minimise it, but it’s tricky to fix if it’s recorded with flicker.
    More technical details and a link to a clip of the problem material might generate more of a response here, without it you’re not going to get much more than guesses.
  • Andrew Clancy
    November 29, 2011 at 9:16 pm
    If by flickering you mean the lights or lighting appear to be flickering then that does sound like the issue I get when shooting on the wrong shutter speed for the situation on a HDSLR. I don’t know a cure I’m afraid, just the prevention.
