Flickering frames
Posted by Ryan Doyle on September 24, 2005 at 12:38 amHey guys,
Im still having the problem of my video flickering during transitions. I’ve uploaded a small section to show you here;
http://www.jeremydeming.com/test.aviThe part I renderd was simply two shots on the same track fading into each other, but it flickers into full opacity frames during the fades. I’ve tried so many things to correct this but Im not sure where im going wrong.
Id really appreciate any help you can give me,
Thanks in advance,
Ryan,
Elysium replied 20 years, 11 months ago 5 Members · 12 Replies -
Ryan Doyle
September 24, 2005 at 12:46 am -
Gary Kleiner
September 24, 2005 at 6:37 amRyan,
What version of Vegas are you running?
What happens if you move the media to a different drive?Gary
Ryan Doyle
September 24, 2005 at 1:46 pmHey,
I am running vegas 6.0.
Theres no change if I move the file to a different drive, though it is 1.5gb. Could it be because the file is too large? I am running it on a 2.4ghz 512m ram 128mb video PC… Could I possibly need more RAM?
Cheers,
Ryan, -
Edward Troxel
September 24, 2005 at 6:02 pm -
Ryan Doyle
September 25, 2005 at 1:32 amHey,
I recorded these files in MPG format using my winfast capture card. Basicly set it to the highest quality and recorded it straight off my camera. They play fine if I view them in media player, but when i start to edit some parts just tend to flicker.
Edward Troxel
September 25, 2005 at 1:48 am -
Ryan Doyle
September 25, 2005 at 2:34 amCrap… i’ve allready returned the camera too….
Is there anyway I can open the whole source video in vegas, then output it as avi then work on it then?
Edward Troxel
September 25, 2005 at 2:42 am -
Ryan Doyle
September 25, 2005 at 2:56 amWould I then be able to rename my old source video, open vegas and then when it asks where the source video is, point it to the new one? would it then pick up all the right parts i’ve cut up and things? or should I just start over?
Edward Troxel
September 25, 2005 at 3:23 am
