Activity Forums Adobe After Effects flickering edge on animated solid
  • flickering edge on animated solid
    Posted by Ed Purver on August 26, 2009 at 3:17 pm
    If I make a low res comp, (256 x 12), and use a solid to create the effect of a white vertical stripe moving horizontally along the width of the comp, when I look closely the edge flickers.
    As the solid moves, sometimes it is blending its edges by one or two pixels with the background (or layer below).
    It is not always a clean edge, but almost as if the edge is feathering by 1 pixel, on and off, so that it appears to flicker slightly as it moves.
    Is it possible to turn off this interpolation and have a solid move with an entirely clean edge?
    (I’m making v low res color animations for LED array lighting)
    Ed Purver replied 17 years, 1 month ago 2 Members · 2 Replies
  • Curious Turtle
    August 27, 2009 at 5:47 am
    In the Layer Switches, turn the Quality to Draft. This will turn off the anti-aliasing and subpixel positioning that’s giving you the problem.
    Cheers,
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
  • Ed Purver
    August 27, 2009 at 6:28 pm
    Thank you!
