Activity › Forums › Maxon Cinema 4D › Flickering artifacts
  • Flickering artifacts
    Posted by Ben Erickson on March 11, 2011 at 7:16 am
    Can anyone direct me to a tutorial on getting rid of flickering artifacts? In the linked video below, I built the sides of the film reel using a boole to cut out the diamond shaped indentations. The flickers are appearing around these indentations. I’ve watched one video that recommends aligning normals which I tried to no avail.
    I appreciate any suggestions.
    https://reels.creativecow.net/film/artifact-problems
    Jakub Jaroszek replied 15 years, 6 months ago 4 Members · 3 Replies
  • Randy Johnson
    March 11, 2011 at 8:43 am
    I would guess that you have two objects in the exact same place.
    Hard to say though.
    /Randy
  • Brian Jones
    March 12, 2011 at 5:04 pm
    As Randy says, hard to tell. Can you post the scene?
  • Jakub Jaroszek
    March 24, 2011 at 7:08 am
    Yes, the problem is that you have multiple faces in the same place. See if you can reposition some of their verticies so that they don’t overlap, that should do the trick.
