Activity › Forums › Maxon Cinema 4D › Flickering animation
  • Adam Trachtenberg
    December 9, 2015 at 6:33 pm
    Yes, it’s almost certainly the low GI settings you’re using. Unfortunately getting the right balance between speed and quality is a time consuming process of trial and error. I would suggest you read the help section on Irradiance Cache at minimum.
  • Marcel Flowerson
    December 13, 2015 at 9:30 pm
    Yes what Adam said is true, using GI is a pain with render times when possible try to stay away from it. What helped me was Bumping up my samples and changing my Anti Aliasing to the Mitchell Filter.
