Activity Forums VEGAS Pro flicker removal
  • flicker removal
    Posted by Wouter Slagter on February 6, 2013 at 7:08 am
    I try to remove the flicker from the gps screen and other avionic screens, caused by different refresh rates, while shooting 1080P – 48 fps
    I can use different camera settings, ( 2.7 k, 1080p- 60,30 or 24 fps ) but do’t know if that would solve the problem.
    I tried to “disable resampling” in Switches but all options are greyed out.
    Any help appreciated.
    John Rofrano replied 13 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    February 9, 2013 at 1:20 am
    [Wouter Slagter] “I can use different camera settings, ( 2.7 k, 1080p- 60,30 or 24 fps ) but do’t know if that would solve the problem.”
    If the screens are using 60Hz electrical current, you might try shooting at 60fps or 30fps. Experiment to see which is better. For the footage already shot you could try Boris FX Continuum Complete BCC Flicker Fixer plug-in.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
