Activity Forums Adobe Premiere Pro Flicker problem.. Help!
  • Flicker problem.. Help!
    Posted by Neil Bradley on May 3, 2007 at 7:21 am
    Help!
    I have been using Premier 6 for a while now and have just upgraded to Premier Pro. My question relates to using imported photos on a sequence. I have imported an image from Photoshop with a transparent background to my sequence. The image fades up then moves off the screen after a few seconds. I was happy to see that Premier Pro automatically registers the transparent background however the flicker my image has as it moves over the screen is shocking. I have a photo and a logo both edited in Photoshop and both with transparent backgrounds that have similar flickers. With my old version of Premier I simply ticked the Deinterlace or Flicker box and the problem went away however when I tick the Flicker box the transparency then registers in white or when I tick the Deinterlace box my flicker is still there. This problem was an easy fix in Premier 6 but I
    Ryan_j replied 19 years, 4 months ago 3 Members · 2 Replies
  • Martin Kraut
    May 3, 2007 at 9:19 am
    Try to change the Field Options for the graphic (right click on it ->Select Field Options->Always de-interlace etc)
  • Ryan_j
    May 17, 2007 at 12:39 am
    If you have Photoshop or alike, knock your image res to 72dpi and
    scale your image down to around the size you want to use it in your
    project ie. 768×576 for 4:3. If it still flickers ad a slight blur to it.
    Cheers.
