Activity Forums AJA Video Systems Flicker on 1080i 10-bit conversions
  • Flicker on 1080i 10-bit conversions
    Posted by Eugene Lehnert on January 5, 2009 at 3:55 pm
    Good day everyone.
    I came back to work today and I have encountered my first FCP/Kona glitch of the New Year. A client gave us 10-bit Uncompressed 23.98 Quicktime files to be printed to a 1080i D5. I was going to layoff the film from Final Cut Pro using the Kona 3 to convert the footage to 1080i from a 23.98 timeline but the Kona card or Final Cut Pro is causing the footage to flicker. The flicker looks like there was a bad HMI or fluorescent light in the scene. When I play the footage as 23.98 it is fine and when I set Final Cut Pro’s output to 1080i 29.97 8-bit it is fine. It seems to only be the 10-bit option that causes this to happen.
    Has anyone seen this? I am using Final Cut Pro 6.05 and version 6.0 of the AJA control panel on a dual 3.0 Ghz Intel Mac. I have checked my reference signal as well.
    Jeremy Garchow replied 17 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 5, 2009 at 5:59 pm
    [Eugene Lehnert] “version 6.0 of the AJA control panel”
    Have you tried uninstalling v6 and installing v6.0.2? You updated the firmware on the card?
    Jeremy
