Activity Forums DaVinci Resolve Flat file workflow…
  • Flat file workflow…
    Posted by Gabriel Regalbuto on September 11, 2012 at 5:30 am
    I’ve had no luck getting a Premiere project into DaVinci. Here’s the lowdown…
    Its a multi-cam project. Multicam, Premiere, and xml don’t mix. EDLs don’t either – matched code notwithstanding.
    Thinking I was super-clever, I brought my rendered file into Premiere, stacked it on top of the original edit, and added edits at every cut. I then deleted the original clips and exported an xml with only the video.
    Brought it into DaVinci and voila! All my cuts are there perfect. Problem is, though the timeline lists 90 clips, and though I am working on clips, not the track, when I grade 1 clip, 89 others do the same thing.
    Has to be simple, right?
    Thanks in advance!
    Joseph Mastantuono replied 14 years ago 5 Members · 5 Replies
  • Margus Voll
    September 11, 2012 at 5:58 am
    look up in manual batch copy or batch unlink.
    this should help you on this one.
    Margus
    https://iconstudios.eu
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Pepijn Klijs
    September 11, 2012 at 6:29 am
    Just my thought as well!
    Editor/Colorist, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
  • Charlie Ellis
    September 11, 2012 at 7:59 am
    find the option in settings tab V8 or conform option section in V9, page 81 of the manual
    “Split source clips for pre-conform”
    This is a better method for approaching a pre-conform..
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
  • Gabriel Regalbuto
    September 11, 2012 at 3:04 pm
    Excellent. Thank you gentlemen!
    FC7 CS5.5
    MacPro 8x
    5drive eSATA stripe
  • Joseph Mastantuono
    September 15, 2012 at 1:49 pm
    All these workflows are clearly delineated in the manual. You could have saved yourself a lot of time if had just opened it.
    Joseph Mastantuono
    http://www.goodpost.net
    Color Grading & Post Production Consulting
