Activity Forums AJA Video Systems Flashing on AJA SDI Output AND on Canvas
  • Flashing on AJA SDI Output AND on Canvas
    Posted by Ben Holmes on September 21, 2005 at 11:15 am
    I have a recently installed Kona 2 card running on a G5 2.7ghz on OSX 10.4.2 with all the latest drivers installed.
    Since installing the card on the system from new, I have experienced small white flashing lines on playback on my canvas window and SDI output from the Kona card (both with and without the KBox). The lines are not from capture, and they do not appear on the same frames every time – in other words they look like the kind of breakup you might get from a bad u-link in an analogue setup or similar (except of course they are not!)
    Initially I assumed this must be a genlock issue – but I have tried locking to external reference in the suite as well as input video and freerun, but the problem is still there.
    To confuse matters further, if I export the sequence as quicktime and drop it into a new timeline, the problem usually goes away – similarly if I nest the sequence and use it in a new timeline. It’s almost as if the number of edit points in the timeline makes a difference – except it doesn’t occur consistently at edit points, but mid-clip.
    None of this makes any sense to me. Do I have a bad card, or is this a software problem. Any ideas?
    Ben Holmes
    Gary Adcock replied 20 years, 10 months ago 5 Members · 19 Replies
  • 19 Replies
  • Jerry Hofmann
    September 21, 2005 at 12:38 pm
    Maybe a software problem… If you didn’t install Tiger as a totally clean installation (as in erase and install), you’ll see some pretty strange stuff…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ben Holmes
    September 21, 2005 at 12:58 pm
    Jerry
    First – thanks for the reply.
    The card was installed on to a new, clean system – and just for good measure we reinstalled OSX of a disc when we unpacked it and did not install any other software except final cut pro and the kona control software. Obviously, when I can get the kit back I will try again – hoping the client (who has dry-hired the system) can output the project in the meantime….
    Ben
  • David Battistella
    September 21, 2005 at 1:45 pm
    Can you give a few more details here.
    What drives, speeed, resolution are you working in. number of streams, filters applied etc., which RT setting is being used System config. ?
    From my experience any kind of flashing usually indicates that there is a drive speed issue. The compter, drives software and hardware can not keep up with what you are asking it too do which makes sense becase it plays a rendered file ine.
    David
  • Ben Holmes
    September 21, 2005 at 2:07 pm
    David
    I hope it’s not the array – although I wouldn’t discount anything as the whole system is new. The array is a Medea Videoraid RT3X Raid 0 running off a UL4D card – dual SCSI 320. In initial tests it ran 5-10 streams off uncompressed 10-bit SD video right into a timeline.
    I have experienced NO dropped frames with the systems, which is otherwise very fast and stable – in fact, the client (who has switched from an old PC based system) was amazed how fast and stable it was…
    I THINK I have seen the flashing on footage not treated on the timeline (although I can’t be certain) but we are not talking about an RT issue here, this is rendered footage (rendered onto the Medea array).
    Sorry to be a little vague – could it be render settings in FCP 5 or white/superwhite processing, or RGB render settings? I haven’t explored that yet, so it is food for thought.
    Ben
  • David Battistella
    September 21, 2005 at 2:41 pm
    With the Medea’s you can be positive it is not drive speed. Maybe you should contact AJA about this as it could be (it happens) a card issue, although I think it has something to do with a filter or setting because the QT is clean.
    David
  • Ben Holmes
    September 21, 2005 at 3:19 pm
    Thanks David. I have put in a support request to AJA about this. I am starting to have my suspicions about the card itself – which could of course be completely unfounded….
    If anyone else has a “oh just select such-and-such in the menu” suggestion for me, or has seen anything similar, please let me know – since I don’t have a problem if I export the project to quicktime and drop it into a new one, I can’t help thinking this has SOMETHING to do with my set-up.
    Ben
    PS – A couple of years ago I would have been thrilled if this was the only problem I had to deal with on a FCP system. How times have changed – everything else worked (on two systems) right out of the box. I am definitely a Kona convert – if I can get this licked….
  • David Battistella
    September 21, 2005 at 3:33 pm
    Ben,
    check out this thread.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=8&postid=860534
    I know it seems like a longshot but what you are describing could be a form of RF noise. They do actaully emit electroonic signals and heck, hospitals don’t let you have them on.
    David
  • Ben Holmes
    September 21, 2005 at 4:57 pm
    David
    Interesting – and good to know, although my cellphone is always on AND I use Lacie for project archives(presumably firewire in that thread) and have never seen that – although we use different frequencies in the UK, so maybe that’s why.
    I have spoken to the client recently who confirms they had the flashing, but got rid of it before edit to tape by exporting the sequence as a clip and playing that out. Not perfect, but at least it works….
    Perhaps if I explain more about the type of break-up it may jog someone’s memory. The white lines flicker on for a frame only, they are not a full line but are only a single line each time, and they are in random vertical positions. It almost looks like a slighty bad analogue problem – except it can’t be, right? I did not mention earlier that I had been unable to get an analogue monitoring output from the Kona 2 card – however I had put that down to something wrong in my Kona set-up. However, I suppose it may be a related fault in some way. Feel a bit stupid for not mentioning that earlier…
    I’ll post when AJA get back to me – the time difference means they have only had a half day to reply so far, so I expect to hear from them soon (from what I’ve read on the Cow).
    Ben
  • David Battistella
    September 21, 2005 at 5:13 pm
    My only two questions are?
    Does this happen in all codecs?
    Does this happen when using a preset window layout or a custom layout?
    David
  • Ben Holmes
    September 21, 2005 at 5:41 pm
    David
    Only seen this in Uncompressed 10-Bit PAL – because that’s all it’s used for at the moment (with HD around the corner here in the UK).
    Desktop layout is a default layout. But this breakup is on the canvas AND the SDI output no matter what layout is used. Nice try though….
    Ben
