Activity › Forums › Adobe Premiere Pro › flash video export in pro?
Posted by Randy Howe on May 30, 2005 at 7:28 pmdoes anyone know if you can exports flash video out of premiere pro or do you need third party software??
David J replied 21 years, 3 months ago 4 Members · 3 Replies -
Mark Remple
May 30, 2005 at 9:16 pmYou will need a third party plugin or conversion program. Premiere Pro does not directly export to swf or flv.
Steven L. gotz
May 30, 2005 at 10:34 pmAfter Effects does.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
David J
May 31, 2005 at 10:43 pmAs far as I am aware, After Effects only supports FLV export if Flash Pro is also installed on that system.
Those with Flash Pro can use the converter to generate FLVs with a number of external programs, including QuickTime Pro, which is a lot cheaper than After Effects.
Haven’t tried it, but this might also be relevant: https://www.tucows.com/preview/374981
However, of the methods I have tried, I have found Wildform Flix Pro to give the best results in converting DV AVIs into FLV.
The official Macromedia line is at https://www.macromedia.com/devnet/mx/flash/articles/flv_exporter.html.
