Activity Forums Adobe After Effects Flash Video Encoder crash AE7.0 Pro – Any clue ?
  • Flash Video Encoder crash AE7.0 Pro – Any clue ?
    Posted by Drtroy on December 26, 2006 at 1:04 pm
    Hi everyone,
    I’m trying to export FLV file with Alpha from AE7.0 Pro.
    Actually, when I do that, the Flash Video Encoder Settings comes up , I choose my settings and click OK but when I do that it stops completely and I have to manually crash After Effects.
    So I did some research and found on Adobe’s website this link about installing 2 files to their original directory which apparently is a common problem with Quicktime :
    FLV.qtx and MMxptResources.dll
    https://www.adobe.com/go/8ddcbd38
    I put these 2 files in the QTComponents folder of Quicktime and copied them back to the System32 file. But it still crash AE7.0 🙁
    Then I have uninstalled Flash8 Pro and the FLV encoder and reinstalled them all from the CD and still have the same problem in AE7.0.
    Though when I open the Flash 8 Video Encoder and try to export a FLV from its window, it works perfectly…
    Guys, I’m lost, if you have encounter the same problem and if you have solved it, I would owe you a big one on helping me on this one.
    Dr Troy, on panic… 🙁
    Luc Bourgeois replied 19 years, 8 months ago 2 Members · 2 Replies
  • Drtroy
    December 26, 2006 at 3:48 pm
    in the meantime I’ll export in PNG Sequence, but I wish I could save thi problem with the FLV encoder.
  • Luc Bourgeois
    December 27, 2006 at 4:18 am
    Hey there
    I routinely export FLV’s with alpha channel using flix an app by https://www.on2.com/ it works as an AE plugin, works like a charm every time. Hope this helps
    Luc Bourgeois
    Cygnus Video Productions
