Activity Forums Adobe After Effects Flash to After Effects
  • Flash to After Effects
    Posted by Samy4movies on September 5, 2007 at 3:37 pm
    Can be possible to import a *swf or *.fla, with all the features done in flash to after effects?
    I have a flash file that I bought for easy construction with a carousel effect that I want to display in after effect.
    Here is the flash sample: https://flashden.net/files/7840/index.html
    Or if this can be done in after effects I would like to know how to do it, it seems that it was easy to do a slideshow then export it as a *.mov or *.avi file but I couldn’t figure out how to render it in flash. I am using CS3 products.
    Thanks for any suggestions
    Samy
    Samy4movies replied 19 years ago 2 Members · 2 Replies
  • Les Lanphere
    September 6, 2007 at 1:07 am
    Option 1:
    This is fairly simple if you have Flash CS3. You’d have to manipulate or remove the some action script, and make a timeline that plays the actual animation you want to see in AE. You can then export a .mov with transparency you can then use in after effects – alpha channel and all.
    If you can’t pull out the actionscript. You could start from scratch and make a carousel using Lee Brimelow’s “Creating 3d Carousels” tuts on gotoAndLearn.com
    https://www.gotoandlearn.com/download.php
    Option 2:
    Make a circular mask in the top view in AE. Copy the path and paste as a motion path for all of your pictures to rotate along.
  • Samy4movies
    September 6, 2007 at 8:19 pm
    Thanks for the advise, I will try out both options.
    I guess I wanted to be too smart to copy what it was in Flash ha?
    Too bad I couldn’t do it, so I have to start all over from scratch.
    But anyway I hope AE Adobe and Flash will be working in make this option happen, work both ways flash2AE.
    Thanks again. 🙁
    Sincerely,
    Samy
