Activity Forums Adobe After Effects Flash To AE
  • Flash To AE
    Posted by Criis Daw on July 12, 2005 at 11:42 am
    Anyone know if its possible to export from flash to quick time including ALPHAs ?
    I am going to have to composit some simple animations made in flash and it would be simpler to to have the backgrounds transparent. If not ( i couldnt find a way) i suppose that i can key out the backgrounds, is there anything i need to consider to ensure that the key out gives perfectly sharp edges ??
    Thanks for any advice
    Chris
    Criis Daw replied 21 years, 1 month ago 3 Members · 3 Replies
  • Frogstar
    July 12, 2005 at 1:56 pm
    HI Chris – I spoke with a AE guru about this very thing the other day. Flash head here and I know you can’t export Flash with a transparent background (well I know as far as I know 🙂
    I was told to do the key thing and also add a slight Gaussian blur to the flash imported layer to give the edge a slight smooth… he suggested about .5 pixel
    hope this helps
    james
  • Dario
    July 12, 2005 at 2:25 pm
  • Criis Daw
    July 12, 2005 at 2:27 pm
    thanks for the tip
