Activity Forums Blackmagic Design Flash Media Live Encoder Does not Work with Blackmagic Drivers 8.5!
  • Flash Media Live Encoder Does not Work with Blackmagic Drivers 8.5!
    Posted by Asaf Blasberg on September 22, 2011 at 11:00 pm
    Dear Blackmagic Design:
    I have an Intensity Pro card on a Mac Pro 2008 using Windows 7 64-bit (Bootcamp)… I was using driver 8.2.1 and using FMLE Version 3.2 to do live streaming… today I installed 8.5 and for the first time, FMLE says “Problem with Video Capture Device – Make Sure it is not in use” — then i go to choose from the pulldown the video capture device and Blackmagic Video Capture Device is no longer there… it is completely gone, which means I am no longer able to stream!… did you remove this functionality? I really hope not.. can you replicate this— go to FMLE 3.2 (Flash Media Live Encoder, v 3.2) for Windows.. let me know if you can replicate… reverting to the 8.2.1 driver fixed this problem.
    Also, do you have an ETA for Premiere Pro CS 5.5.1 ?
    Asaf Blasberg replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
