Activity Forums Adobe Premiere Pro ‘flash frame’ playback issue with Premiere Pro CS6 + CUDA enabled Mac + Blackmagic I/O
  • ‘flash frame’ playback issue with Premiere Pro CS6 + CUDA enabled Mac + Blackmagic I/O
    Posted by Paul Jay on May 31, 2013 at 10:32 am
    There is a playback issue with Premiere Pro CS6 + CUDA enabled Mac + Blackmagic hardware.
    When you scrub through a sequence and hit play, you see a ‘flash frame’ from the last shot before it starts playing on your reference monitor.
    This issue can be reproduced by anyone that has a Mac with CUDA GPU and a Blackmagic I/O.
    I’ve tested this on a MacBook Pro Retina with Ultrastudio 3D
    New generation iMac + Nvida GTX680 MX + Ultrastudio 3D
    Mac Pro with a GTX680 for Mac + Decklink 3D
    All systems running 10.8.3 with latest Premiere CS6 , CUDA driver and Blackmagic 9.7.3 driver.
    Footage doesn’t matter. It happens with ProRes, h264 footage etc..
    When you disable CUDA in Premiere and set to Software Only the problem is gone.
    It looks like a Premiere related caching issue from the CUDA card to the Blackmagic I/O.
    Because DaVinci Resolve on all these systems runs flawless with the Blackmagic I/O.
    Would be nice if this issue will be fixed.
    Anyone can test this.
    Just scrub and hit play and look at your reference monitor.
    Jon Howard replied 12 years ago 2 Members · 1 Reply
  • Jon Howard
    August 21, 2014 at 4:47 pm
    I’m having the exact same issue. I used to be able to fix it by preceding a blank spot in my timeline with a clip of black video. Now that doesn’t work. Did you ever get any resolution on this issue?
