Activity › Forums › Adobe After Effects › Flash export from AE
  • Seth Taylor
    July 18, 2005 at 4:16 pm
    you can render a png sequence to import into Flash
  • David Modijefsky
    July 18, 2005 at 5:37 pm
    Thanx Seth, but after import in Flash will I be able to export a file with an alpha channel? Because that’s what I need. I’ve tried animated gifs but they don’t come out smooth. The idea is to import this animation over a full screen texture in Freeway.
  • Brant Mills
    July 19, 2005 at 2:57 am
    I agree that the animated gif export from ae is crap. I had to find a workaround for site design stuff. If you output a jpg sequence to its own folder you should be able to import that into flash – or alternately (to save the time it will take flash import the sequence and later to export a larger file) you can make an animated gif out of the jpg sequence in imageready and you can then open a high quality animated gif directly in flash. I’m not sure on the alpha channel issue though. Hope this helps.
  • David Modijefsky
    July 19, 2005 at 12:33 pm
    Thanx Brant. I’ve messed around with ImageReady but my knowledge of this app is limited. I couldn’t even scale it down in filesize. So I stick to what I (more or less) know and take you idea of jpeg seq. into Fireworks. Time is closing in. Lucky for me it’s a charity job 😉
