Activity Forums Apple Final Cut Pro Legacy Flash Card Won’t Show In Final Cut
  • Flash Card Won’t Show In Final Cut
    Posted by Josh Robinson on March 14, 2012 at 12:15 am
    Let me explain:
    Never had an issue before with Final Cut locating the footage through Capture/Transfer.
    Using Lexar Pro Card at x400, 32G with a Lexar 3.0 USB card reader.
    All past cards work just fine except this one, though no settings have been changed on anything.
    The footage is on the card because it still shows as .m2t files and I can use mpeg streamclip to convert to .mov…
    I’m also just capturing it from a tape the footage was recorded on just so I can turn this video around as quick as usual.
    But what could have gone wrong when nothing changed?!?
    I do notice a difference however in the files on past cards versus this one. This card has the .m2t files and a tracks.dat file.
    Past ones include .idx files…So that is probably where something went awry, though I hadn’t changed any camera settings or FCP settings I thought.
    Please help me out if you can. Thanks so much.
    – Josh
    Josh Robinson replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
