Activity Forums Adobe Premiere Pro Fixing moire effect while panning
  • Fixing moire effect while panning
    Posted by Ruby Gold on June 18, 2005 at 6:26 am
    I’ve created a “pan” effect over jpgs of several paintings for a production I’m making in PPro 1.5. I’ve keyframed changes in scale and position within PPro 1.5 to create the pan effect. A bad moire pattern appears during the pans in many of the paintings and I’ve tried to fix it in Photoshop 6.0 using a slight Gaussian blur and/or a despeckle filter. They don’t make any noticeable improvement. I’ve also tried changing the field options on the images within PPro to anti-flicker or always deinterlace. Again–no significant improvement.
    Any other tricks/suggestions for lessening or removing the moire during pans greatly appreciated.
    thanks-
    David J replied 21 years, 2 months ago 2 Members · 1 Reply
  • David J
    June 18, 2005 at 8:45 am
    Where are you judging th quality of the output?
    If on the computer screen, then you may be misjudging what will appear on a TV due to limitations in Premiere’s rendition of interlaced footage. Look at TV output before accepting that there is a quality problem.
    If this is not the issue, then it would be helpful to eliminate it from consideration.
