Activity Forums Adobe After Effects fixing mattes from videotape
  • fixing mattes from videotape
    Posted by Dan O’brien on August 22, 2006 at 9:36 pm
    I have some old fills/mattes from digibeta that I’m combining into QTs with embedded alpha using AE 6.5. The problem… when I import the QTs back into Avid, the elements are a little bit transparent. I then looked at the matte color, and noticed it was not quite 100% white (it was about 234 rgb). I tried the “replace color” effect to increase the white levels and it works, however the soft edging of the mattes are now lost a little. So my question is… how can I boost the overall white levels of the mattes so they key correctly?
    Dan
    PrEditors.net
    Dan O’brien replied 20 years, 1 month ago 2 Members · 2 Replies
  • Coverbee
    August 22, 2006 at 9:50 pm
    Hi
    Try this one
    Effect>Adjust> Levels
    bring the percenyage for “input white” back.
    Does it work or am I just being to simple..
  • Dan O’brien
    August 22, 2006 at 10:04 pm
    You’re not being too simple… I’m being too stupid!
    It worked fine… just had to find the sweet spot… Thanks for your help.
    Dan
    PrEditors.net
