Activity Forums Adobe Audition Fixing a singers words
  • Fixing a singers words
    Posted by Larry Watts on September 5, 2007 at 2:22 pm
    I’m trying to fix an area where a recording artist (singer)forgot the lyrics and faked it. Later in the song the singer got it right.
    In edit view I want to cut and paste and being new to audition want to make sure I get it Right!
    It appears that I should use the “replace” setting for paste which does not change the length of the song. The other settings seem to ad time.
    Am I correct?
    Is there a better way?
    Larry
    Larry Watts replied 18 years, 12 months ago 2 Members · 2 Replies
  • Willie Toth
    September 5, 2007 at 7:13 pm
    Personally I would edit this on the session side … Highlight the correct area right click on the first empty track below it do a mixdown of the selected area and then match it up to the area you want to replace … Once you have done that highlight the bad area and right click on it then cut … Don’t forget lock the new clip in time before you move it up ……… WILLIE
    PS If you are looking for a “click of the mouse fix” you won’t find it if you want quality audio …
  • Larry Watts
    September 6, 2007 at 7:14 pm
    I did that and it worked perfectly. Impossible to tell it was not that way originally.
    thanks
    Larry
