Activity › Forums › Apple Final Cut Pro Legacy › Fixing a blown out background
Posted by Justin Mitchell on August 7, 2009 at 8:16 pmI’m busy editing a video and in one of the interviews the background is very washed out. It was shot outside in front of a lake and the lake appears almost white, the sky is completely white and the trees are quite faded as well. The subject looks fine though. I was wondering if anybody had a good technique to fix this.
JustinLon Keller replied 17 years, 1 month ago 6 Members · 5 Replies -
Shane Ross
August 7, 2009 at 8:41 pmWell, not much you can do…the information is lost in that blown out area. But there are plugins that can pull out what detail is there:
https://straylight.tv/pluginz/
The LOOKS SWEET package has Mr. Fixit, and that is great for pulling out what detail there is in those bright spots. I use this myself.
There is also the Capt’s Blowout Fixer…that is free. Not as good, but worth trying too, no?
https://pistolerapost.com/pluginz/index.html
Shane
Read my blog, Little Frog in High Def -
Russell Lasson
August 7, 2009 at 8:42 pmUnfortunately, you’re in a bit of a pickle. The white information is likely clipped, meaning that there’s no more detail there. If you pull it down with color correction, it doesn’t allow for any more detail and it just turns shades of grey instead of white.
Option 1: Reshoot
Option 2: Rotoscope person and put in a new background
Option 3: Settle for some sort of look to minimize the clipping in color correction
Play around with it and post some stills if you want. Helps to see what you’re actually talking about.
-Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net -
Nick Meyers
August 8, 2009 at 3:29 amanother useful “blowout fixer” is a freebie from Lyric:
<https://www.lyric.com/fcp-plugins/>you may also want to mask of the sky, lake and any land,
and give them separate colour washes / grades.nick
John Fishback
August 8, 2009 at 8:03 pmYou could use Color affect the sky and lake.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Lon Keller
August 8, 2009 at 10:46 pmRuss,
You forgot option 4: String up your shooter by his thumbs! OK … that won’t fix the video, but it may make you feel better! 😉
Lon Keller
Chief Editor / Producer
Sundog Studios
