Activity Forums Maxon Cinema 4D Fixed helix to a point without converting to points
  • Fixed helix to a point without converting to points
    Posted by Noa Xavier on June 28, 2020 at 9:40 pm
    Today I have a problem that would be typically quite easy to fix if my object were made into an editable spline, or if I were using a cloth belt or even Xpresso to attach a point to a null.
    Today I want to attach an object to null, that way when I press play it doesn’t fall as a result of gravity but remains a soft body that way I can animate collider bodies to interact with it.
    Here is my file:
    https://www.dropbox.com/s/49f2148mch1up3u/attachto.c4d?dl=0
    Noa Xavier replied 6 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
