Fixating on the perfect HD Monitor
Hey Guys. I thought you all might want to hear about my research for the best HD Monitor out there. Here’s the info I’ve gleaned over about a dozen hours of research.
1. Although LCD and Plasma HD monitors look great and some even can be said to be wonderful edit monitors (Panasonic’s BT-LH2600W in particular) none of them are as good as a current or discontinued SMPTE-C Phosphor, HD/SD CRT monitor in terms of judging picture for true color correction and grading. My plan is to buy a used CRT and then dump it as soon as something as good comes out as an LCD or Plasma. Everyone seems to agree that the tech hasn’t reached that point. Maybe this NAB???
2. There are 3 good choices out there from what I can find. All are used. I’d love for some input on these if anyone is using them out there. They are as follows:
a. Sony PVM-20L5 —– 20″ HD/SD, 4:3 Native 16:9 Masked . . . 800 lines of resolution in SD. Seems to be the “standard” for older CRT HD Monitors
b. Ikegami HTM-3202 — 32″ HD/SD?? 16:9 Native 4:3??? . . . . 1000 lines of resolution in HD! Not sure if it will handle a SD signal. Massive monitor. 178lbs!
c. JVC DT-V1910CGU — 19″ HD/SD, 4:3 Native 16:9 Masked . . . 900 lines of resolution in SD. Needs optional cards for inputs (Standard setup is no inputs at all! Same trick Panasonic’s pulling with not including a viewfinder with the HDX900)
So, those are the monitors I’m looking at. Anyone that can compare these monitors or anyone with other solutions out there would be most welcome to chime in!
Thanks for the help.
Tim
