Activity › Forums › Maxon Cinema 4D › Fix particles postion at a given time
  • Fix particles postion at a given time
    Posted by Alan Lacey on April 22, 2007 at 1:42 pm
    I know it’s possible to bake a particle solution but what I’d like to do is fix the paticles in a given postion at a certain frame, and then discard all the other particle animation info.
    Paul Everett wrote a script called ‘magic bullet’ which freezes the particles at a given frame but I’m just after a certain particle distribution to act as a framwork for a static pyrocluster look.
    thanks for any help
    Alan
    Alan Lacey replied 19 years, 5 months ago 2 Members · 6 Replies
  • Brian Jones
    April 22, 2007 at 7:01 pm
    With regular particles you can use a Friction object set it to 0 for as long as desired then to ‘freeze’ the particles set it to something ridiculously large like a million. For TP use a PFreeze node.
  • Alan Lacey
    April 22, 2007 at 7:16 pm
    Thanks Brian I’ll give it a try.
    To get my particles in position on the first frame of the animation, does that mean that I have to run the particles before t=0 and apply friction at that point?
    Alan
  • Brian Jones
    April 22, 2007 at 7:44 pm
    yes
  • Alan Lacey
    April 23, 2007 at 4:36 pm
    Thanks again Brian.
    Do you happen to know if there is there any other ‘static’ framework that pyrocluster can build on other than particles?
    Alan
  • Brian Jones
    April 23, 2007 at 7:46 pm
    not that I know of, PyroCluster works with ‘any C4D compatible particle system’.
  • Alan Lacey
    April 24, 2007 at 4:08 pm
    hmmmm, feared so.
    Thanks anyway Brian. The friction trick worked but is a bit unwealdy for what I’m after.
    Alan
