Activity Forums Adobe After Effects fix motion blur
  • fix motion blur
    Posted by Jonathan Hudson on February 21, 2007 at 2:36 am
    i accidentally used a lower shutter speed than i wanted and the footage ended up too blurry, is there any way to fix it with good to great results? i use a jvchdgy110u and shot in 720 24p. i use after effects 6.5 and shake 4.
    Peter Litwinowicz replied 19 years, 7 months ago 3 Members · 2 Replies
  • David Bogie
    February 21, 2007 at 2:51 am
    Nope.
    bogiesan
  • Peter Litwinowicz
    February 21, 2007 at 5:12 am
    Depends on how blurry is “too blurry”.
    You can try our ReelSmart Motion Blur which uses motion compensation to add motion blur, but the plugin can also remove motion blur (if it’s not too extensive). Of course, trying to remove motion blur from an image that is really blurred will have the same problems you have unsharp masking an exceptionally out-of-focus image.
    Why don’t you give the plugin a try: https://www.revisionfx.com/products/rsmb/ There is a free demo version in the “Downloads” subsection for the plugin. Also, make sure to read the short manual that is put on your disk with the plugin upon installation.
    Pete
