Activity Forums VEGAS Pro Fix minor defects with smart rendering
  • Fix minor defects with smart rendering
    Posted by Fabio Mereghetti on October 21, 2010 at 3:45 pm
    Some hours ago I have finished an mpeg2 rendering of a project that took two days.
    Now, I discovered a mispelled title overlayed for two seconds on a clip.
    Do you know an easy way to edit those two seconds and avoid another two-days campaign to render everything to DVD Architect video stream?
    I have the original project with all the media and I have the just rendered mpg file.
    Thanks.
    Fabio Mereghetti replied 15 years, 10 months ago 2 Members · 2 Replies
  • Scott Francis
    October 21, 2010 at 4:54 pm
    When I have done that, I re-render out only the part I messed up and then create another project, bring in both the full-sized bad clip and the small fixed clip, line them up and re-render the project using the same format as the full length bad clip. This will allow it to smart render a new clip and only need to make any changes to the fixed part. Hope this helps!!
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • Fabio Mereghetti
    October 22, 2010 at 10:54 am
    Thanks.
    I thought of that way but I was not sure.
    In fact, I still am not.
    I put the .mpg bad file, the one previously rendered as DVD architect video stream, on the timeline of a new project and on the track above I put the two seconds good clip (rendered as avi uncompressed).
    I set the project as the original one (DVD Widescreen PAL None (progressive) and deint. method “interpolated” and set the mainconcept rendering the same.
    I’m getting a rendering speed of about 1 min of clip (1%) in one minute of time, where there are no corrections.
    I did expect a far faster “encoding” speed for the unrouched sections: how do I know if Vegas is decoding + re-encoding everything instead of just the edited parts?
    Thanks.
    Fabio.
