Activity Forums Apple Final Cut Pro Fix for Retime “thumb” not working
  • Fix for Retime “thumb” not working
    Posted by T. Payton on August 8, 2011 at 11:46 pm
    I had a problem with retiming on a long format project (2 hrs) where the retiming “thumb” stopped working in FCP X.
    After a frustrating few hours I discovered there is a “Reset Timing” function. Just select the clip, choose “Reset Timing” from the retime menu or option-command-r. Then the “thumb” works again as expected. This works for both audio and video.
    Tuck this away in case you need it in the future.
    T. Payton
    OneCreative, Albuquerque
    T. Payton replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
