Activity › Forums › DaVinci Resolve › Fitting a GTX 580 in a Mac Pro
Posted by Ryan Snook on May 24, 2012 at 2:10 pmSo who has successfully fit a GTX 580 in their Mac Pro (preferably an Early 2008) and could actually shut the side panel with all 3 power connectors connected…
Even if i cut the hell out of that case and ran cable perfectly, those power connectors coming off the side of that giant card would be flush with the edge of the case even if bent and broken at a 90 degree angle…
How is this done? Run with case open? Go to a blacksmith and buy a custom made “2 inches more wide” side panel?
Ideas? Comments? Slanders? Anything?
Ori Dè rascher replied 13 years, 12 months ago 8 Members · 15 Replies -
Colin Travers
May 24, 2012 at 2:28 pmI have a 12-core 5,1 MacPro but the cords fit in and the door shuts fine so I am not really sure without a picture what the problem is with your setup. Maybe the cords are too long?
DaVinci 8.2.1 beta3
OSX 10.7.4 (SSD in second optical bay)
MacPro 12-core 5,1 2.66 Ghz
32GB RAM x4 8GB
Software RAID 0 (8TB Internal)
Nvidia GT120/GTX580 (CUDA 4.2.7 / GPU 1.3.4.0)
Decklink Extreme3D
FSI LM-2461W / Panny VT25
Tangent Wave / Wacom -
Juan Salvo
May 24, 2012 at 2:43 pm3 power connects? There’s only two. You didn’t get the “classified” edition did you?
Online Editor | Colorist | Post Super | VFX Artist | BD Author
Paul Jay
May 24, 2012 at 3:06 pmI hope you have a daily (hourly) backup with that 8TB RAID0 system. 1 disk fail and it’s over.
Juan Salvo
May 24, 2012 at 3:41 pmThe classified doesn’t work in the Mac Pro. The standard edition barely gets by in a Mac Pro. Classified requires 30% more juice. Closing the case is the least of your problems. Return it and get a standard 3gb 580. It fits.
Ryan Snook
May 24, 2012 at 4:03 pmI have a dedicated GPU 450W power supply fits into optical drive bay ) for both 8 pins and a 6 pin. Functionally working fine, but I cannot close my case…
Are there like very flexible low profile cables available?
Blase Theodore
May 24, 2012 at 4:36 pmWithout dremelling the case, it doesn’t seem possible. I have the same setup, and the power cable hangs out the side of the case.
Ryan Snook
May 24, 2012 at 4:43 pmIt’s ridiculous isn’t it? Do you sometimes feel that Steve still gets the best of you even from the grave when you attempt to upgrade his trash to a standard that meets our modern day?
Margus Voll
May 24, 2012 at 6:50 pmyou could extend cables out from optical bay door and put psu on top of the machine.
side panel would still be the problem.
do you have standard pc card or have David flashed it ?
Margus
DaVinci 8.2.1 OSX 10.7.3
MacPro 5.1 2×2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro -
Ryan Snook
May 24, 2012 at 7:02 pmYeah… I have an optical bay dedicated power unit that is working fine – but the connectors alone stick out past the side :(.
Its a standard card, I have not had it flashed yet.
