Activity Forums Adobe After Effects Fit keyed footage to 3D space (shadows)
  • Fit keyed footage to 3D space (shadows)
    Posted by Dino Muhic on April 2, 2009 at 3:52 pm
    Hi, I’m trying to set a keyed guy into 3D space in AE with AE lights and shadows.
    But it’s kinda hard to get the same angle and position of the camera. The floor is a solid turned 90° and with a ramp on.
    His feets are not touching the ground correctly (only his teos do).
    What should I try? The only thing I came up is to paint a new shadow for the complete sequence just to visually make contact to the ground.
    Any ideas?
    How would you build it up?
    Thank you very much!
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
    Dino Muhic replied 17 years, 5 months ago 4 Members · 5 Replies
  • Paul Conigliaro
    April 2, 2009 at 3:57 pm
    It’s hard to tell from that still, but would you be able to turn the floor more/less than 90° to match to the physical floor the talent is standing on? Try turning off your key and visually matching the 3D & physical floors.
    CS3, FCS2
    [Note: Using Particular, 3-D Stroke, and now Form do not instantly make your designs “teh awesome.”]
  • Steve Roberts
    April 2, 2009 at 4:38 pm
    Yes. In other words, either the original camera angle was wider than your AE camera angle, and/or the original camera was higher and tilted down more than your AE camera.
  • Dino Muhic
    April 2, 2009 at 5:32 pm
    Thanks guys but I tried it all out. Wide and narrow lenses, tilting the floor and positioning the camera but somehow I can’t get the shadows right.
    Here’s the raw key footage:
    I really would appreciate it, if one of you could just try it out.
    Place it into a 3d scene with camera, floor and 3 spotlights in the back, casting and accepting shadows turned on on every layer.
    I think it’s just plain impossible since it’s just a 2D layer and the toes are not at the same height as the heel….
  • Peter Van der zee
    April 3, 2009 at 3:10 pm
    I had a moment during renders and I looked into your problem
    I put a 600 zoom camera at -600 and the floor even at 90º is more or less acceptable
    it’s then at 1044 Y and 1500 in Z but to adjust even more at 80º it comes up to 779 Y
    and I think you can sell this (don’t look at the key)
    a href=’https://i1.creativecow.net/u/85977/shadowproblem20.00.00.00.jpg’>
    http://www.zeemotion.com
  • Dino Muhic
    April 3, 2009 at 4:10 pm
    Thank you Peter!
    I’ll try it out immediately!
    Cheers
